So here’s the story, I’ll try and explain everything in a list order so it might be easier to identify the problem:
VESC X ARRIVED
Soldered to 4x 3S lipo in series, and 5.5mm bullet connectors
Setup in BLDC Tool Settings for step 3 setup: BLDC (no sensors Motor max 60 Motor min regen -40 Battery amp max 60 Overall max amps 130 Battery cutoff start: 44.4 Battery cutoff: 43.2
Ride, board works flawlessly and goes 45kmh
One phase wire comes loose, resolder.
Configure in BLDC with sensors Speed goes down to around 25-30kmh
Remove sensors leave on BLDC: speed still the same
Firmware reflash: default settings, enable FOC, now speed is 10kmh.
Any ideas what the problem could be? I will send screenshots later tonight and I will measure battery output voltage. Cells are at 3.91 each
Thanks guys, hope I can get this resolved quickly so I can start riding. I’m thinking it could be my battery voltage cutoffs? Should I try charging?
