Newbie here. I am building a mountainboard. Trampa with Dual VESC6, 12S, and I want to install a Bluetooth adapter.
However, there is a warning in the vesc-project forum. WARNINGs!! What you should not do! stating that “… equipment that was designed for VESC 4 should not be used with VESC Six, until the vendor has stated that it is compatible.”
I already have this Bluetooth Adapter
I check with @trampa, and Frank said that the adapter probably would not work and the software would get messed up… And that TRAMPA is working on a better solution. Or I could check with Roman, at Metr.at. (thanks for the info Frank!)
I also did check with the seller, @oriol360, and in his opinion, the adapter should work, but has no direct experience.
I would not like to risk messing up these expensive VESCs. Has anyone tried this module on a VESC 6?
The connector seems to be ok, There is a match between the BT module and the VESC6 connector
1 blue tdx 2 green rdx 3 4 black gnd 5 red vcc 6
This is a picture of the connector installed, but I am not brave enough to connect the battery and test…
