Hi,
I am building my first build. The first time i programmed my Vesc in Vesc-Tool (FOC mode) everything was ok, then i wanted to change the braking force a bit and while i was programming the TorqueBoards Vesc just died. I bought another one, this time the FOCBOX, it died the same way. I have no idea if I am programming the Vesc’s wrong or if they die from another reason. Does anyone know how to help? Or should i just use the BLDC Tool
I am using this guide for Vesc Programming: https://www.youtube.com/watch?v=v1glLDO-EjA&t=730s
My Setup:
TorqueBoards 6355 Electric Skateboard Motor TorqueBoards single motor mechanical kit TorqueBoards Nano remote 3x 3s Zippy Compact 2700mah lipos in series(going to change them)
