Looked around on the forums for help but I could find anything to help.
190kv
10s4p
Vesc 4.12
At full charge and up to 3/4ths throttle everything is fine. When I hit full throttle sometimes the vesc cuts out, I have to break a little then I can continue riding.
When the battery starts getting lower full throttle doesn’t seem to bother it as much.
I can ride around all day with no issues if don’t go full throttle.
The following faults were registered since start:
Fault : FAULT_CODE_UNDER_VOLTAGE
Current : -0.2
Current filtered : -0.1
Voltage : 8.00
Duty : 0.950
RPM : 10722.7
Tacho : 107023
Cycles running : 0
TIM duty : 4560
TIM val samp : 1200
TIM current samp : 3600
TIM top : 4800
Comm step : 3
Temperature : 56.14
Current : 0.6
Current filtered : 0.1
Voltage : 8.00
Duty : 0.950
RPM : 10789.4
Tacho : 120744
Cycles running : 0
TIM duty : 4560
TIM val samp : 1200
TIM top : 4800
Comm step : 2
Temperature : 55.61
Current : 0.2
Current filtered : -0.2
Voltage : 8.00
Duty : 0.950
RPM : 10663.5
Tacho : 123542
Cycles running : 0
TIM duty : 4560
TIM val samp : 1200
TIM top : 4800
Comm step : 4
Temperature : 55.53
vesc settings
Motor current 70a
Max break. -60a
Absolute 130a
Battery 50/-50
Voltage cut off 34-31
This exact thing happens when I was testing my unbalanced battery. It was due to the BMS freaking out and cutting off load. Are you discharging through your BMS?
Just battery current. Also your battery min is WAYYYY too high. What pack do you have 10s?p and what cells?
EDIT: nvm i see it’s 10s4p, but would still like to know the cells. 50 amps should be fine for it unless they’re fake cells, though they might have included a shitty BMS
If you are dead set on not changing battery packs for the moment you might be able to drop some rather large caps in parallel with your pack. I know that the vesc’s have their own but some ultra caps might be enough to make the sudden current draw a little less harsh.
I would say bypass the BMS and just ride with a fire extinguisher if you just want all the current though.
@JakeSkate Got a link on how that works? I’d like to learn more about that stuff.
Lowering the current pull from the battery seemed to help. I didn’t fully get on it yet.
