Hello guys! I built my first ESK8 a year ago with a standard 6S 5500 mAh LiPo battery, 400KV Motor, and a cheap Banggood ESC (it’s shit ik…xD)
And now as the battery is almost drained, i wanna upgrade the battery with a selfmade 6S5P batterypack using the Vruzend 2.1 Battery Build Kit! The idea, to use that, is cuz when i build a completely new ESK8, then i can reuse the cells for a bigger pack, like a 10S3P or add more cells (depends on how much energy used)
My next build will defo be a dual motor setup with with lower KV (like 170-260KV) to get more torque with a fitting battery (10S or even 12S) and ofcourse a dual VESC/Focbox…
but for now, i just wanna upgrade the battery!
So i made this simple schematic, on how i would wire the battery with the BMS.
Cells: https://eu.nkon.nl/samsung-inr-18650-30q-3000mah.html
Vruzend 2.1 Kit: https://www.ebay.com/itm/NEW-Vruzend-V2-1-DIY-Solderless-18650-Battery-Holder-No-Spot-Weld-Colour-Coded-/323873942375
It would be cool, if someone could say, that this is a good plan or not!
thank’s you for the answers! Cells will arrive this week!
