I have 5v LED strips I want to power up. I tried using a USB stick but I went over some bricks and it vibrated the USB stick to a point it wouldn’t turn on anymore (only took minutes lol). I rather just wire it into the ESC or inline from battery. Possible? If so, how?
Any 5v supply from that esc is most likely going to be low amperage, thus I would not wire anything to it. You’d need to add a buck converter to your Li-Ion output.
Yeah I was thinking that. So based on the kit and battery I purchased, what kind of buck would I need to get? Confused as to the specs I’d need to be within range of.
Yup… They don’t mention the pack voltage/for you to figure out. Get a multimeter, ask the vendor, see if it’s mentioned on the label of the pack or elsewhere.
Since the led strip has a USB connection, I am Going to assume the led strip needs 500-900 mA (USB 2 vs USB 3). It’s always a good practice to get something that delivers a bit more, thus I’d recommend a buck converter capable of delivering 1.5A at 5v.
Thank you for the help! I get the device tomorrow so hopefully it’s an easy fix. Was super annoyed when my USB charger died at the start of my ride because of the rattling on a brick street.
