That’s what I’m talking bout. The vinyl you showed me came in yesterday. So I’m going to trim Angel’s Bride with the Carbon. Thanks to you.
Yeah looks nice … Don’t forget to rub it firm and go over it with the hot air gun … Needs to be hot with fanning motion …
You don’t need to worry abt air bubbles it don’t happen with this sheet
Ok so Sensored motors and ESCs
This is a GoolRc Car esc … Cheap and so far all have worked well…but have been unsensored
Wire by color?
How do I insure the proper connections?
You can do it the scientific way or my way. I plug the phase wires in according to color then hit the throttle quickly. If it makes a weird noise or hesitates I switch the phase wires around. Just don’t hit throttle too long or you’ll fry something. It should end up sounding normal, if they are plugged in correctly.
Thanks dude … I’ve seen it done that way.
Hey mike where do u get those blue wires from?
Que? Blue wires?
That blue wire
It was already there mate
You can buy blue silicone wire from HK
Working on the front lights
From this hot mess
To this
There are two off white 15w head light…plus a stuck a light in the riser since it’s clear …
Also made some changes which I will mention later when I finish this up
Like the lights. Really gives that setup a boost. How do you wire it separate from the rest of the board?
It’s part of the board electrical system
All running on the same current? No relay switches?
Lol no…
12v lighting system
Ok, was wondering. How would one tap into battery pack like hooking up a USB to charge other devices?
