Hi there! I was thinking today…
how do you tell when you should start thinking about heading home and how do you tell when batteries are getting low?
I think evolve had a good idea that it shows kilometers made or kilometers left on their new remote…
Thinking in similar fashion, I thought there could at least be some sort of beeper, similar like lipo alarms has, but for different voltage levels… let’s say, one beep is when you reach 50% battery left, then 30% left has 2 beeps, then 15% left has 3 beeps…
I know u guys use these ‘‘coulometers’’ where the voltage / battery is shown as percent and you probably judge your distance from that… but with this topic I wanted to come up, perhaps, with a few innovative / unique ideas, which could be used or implemented…
I think a good way is also to put voltmeter in front of the board or just make a simple 4-5 led indicator, which also shows the voltage / battery left with how many leds are light (or in which color…)
Anyways, Im using wattmeter myself (with total voltage shown), so basically when voltage is around 21v (in my case) I know the cells are around 3.5v and that’s when the ride should be soon ended… but it is a bit hard to tell how much juice I got left when im in the middle range… so a display with percentage would be better suited for this…
Lipo alarms (cheap ones) suck in this application, they are quite loud and it is not easy to turn them off once they start buzzing… plus, for me they are inaccurate and show a big wrong voltage for a few cell groups.
