Hello, just got back to upgrading my board and got really confused with the BMS, let me explain:
I have two 6s batteries connected in series, and I bought a 6s 10A BMS for easier charging (charge only) but after soldering everything and trying to connect the balance cable to the BMS port, I couldn’t get it in there, and then I noticed that it wasn’t the “normal” 6s port, it was smaller.
So my only way of connecting a balance cable to the BMS is connecting the one that came with the BMS, but that one has no connectors on the other side, and I don’t want to start soldering tiny balance cables.
What are my options here? should I just get a different BMS with a full-size port? Is there any adaptor from the smaller 6s to the standard one?
I took some pictures to make it clearer:
