I went out on a ride today and noticed some weird sound coming from the motor plate. The mount is hooked up fine and i don’t think belt tension is bad, see video for what the tension is like, but there’s just this in and out movement on the mount when i am acceleration or carving to the right. I’m not sure if it’s the pulley of if my bearing is shot/core is bad. No idea what it could be. see video for reference. I don’t think it’s normal as it wasn’t doing this before. Only thing i changed on both motors was the angle that they sit at. I angled it a little bit more towards the deck for more clearance.
Any help is appreciated
Looks like the motorplate bends.
Are you sure your wheel pulley is nicely centered?
Do you feel different belt tension when you turn the wheel?
Maybe you got a little rock stuck into your wheelpulley?
Hm… what would the problem be if it was different belt tension when i spun the wheel? like what would be the best way to remedy that situation? because visually the pulley looks very aligned and i don’t think a rock is stuck there, i will still check later tonight. No pulley teeth ground off, looks good as new
That’s pretty tight tension. That can stress the motor shaft and may cause it to bend, or warp the bearings, which would result in an uneven can when spinning.
I would decrease the tension. Belts, especially wider belts, don’t need to be very tight.
