For my build I bought a 12s BMS( I orignally planned to do a 12s system)
After specking my motor out I decided stay below the 60,000 erpm’s so I would prefer to just run an 11s system.
Any ideas on how to pull that off?
Hardware
-11 5000mah 1s batteries
-44V 48V 50.4V 12S 60A Lithium ion Li-ion LiPo Li-Polymer Battery BMS PCB System
Could I possibly just wire in a small resistor and make a “12th dummy battery”, I have no idea.
Anyways any help would be much appreciated. Thanks
Turn off the " Limit ERPM with negative torque
And set limits to -60k and 60k
You’ll likely not exceed 60k anyway unless your flying down a long steep mountain road or turning your board upside down and pulling the throttle
