My build is 100% done, I just can’t get my bluetooth module to connect. I’m using the HM-10 module with the Xmatic ios app by @twan however I cannot get my phone to find it. I’m using an iphone SE and have the latest update to his app. Yesterday I noticed the wires connecting it to the UART port on Vesc were all out of order, so I rewired it to how it should be wired according to the settings displayed on the app. The wiring is now
Bluetooth Module-UART
RXD-TX
TX-RX
GND-ADC
VCC-5V
I still can’t even get an LED to flash on the module, is it me or is it a faulty pcb?
Edit: I’ll tag @b264 because I’m confident he can help me solve this
I am having the same problem. I am running fsesc 4.12. bt mod would not connect or transmit any data but everything was working b4 I upgraded to the new vesc firmware. But if I use the bt mod by flipsky things work
You could check with a cheap voltmeter and a 1,5 volt battery, just remove the pins from the jet and close the circuit through the batt, you should be able to find ground… hope it helps
Ok so I’ve made progress. My phone is able to connect to the Bluetooth module after some rewiring, however it just keeps saying connecting to Vesc. I am positive that I have set the Vesc to ppm and uart and baud rate to 9600. Are there any other settings that need to be changed?
