I gotta say reliability, especially in the motor and battery departments.
Motors take a lot of abuse being so close to the ground and depending on the use case can get overly hot or knock into something and shatter a magnet or damage a bearing. Batteries only last a few years of heavy use before decreasing in capacity and are not a very good investment imo.
Reliability is a big, huge problem, but it’s currently solvable – people just don’t want to pay for it.
Battery weight is the biggest bottleneck that isn’t solved yet.
If you had a choice to buy a $1000 new car that worked awesome for the first 5 miles but then breaks down, you wouldn’t buy that. But people think it’s okay for esk8, for some reason.
There is one company treating esk8 engineering as automotive engineering… can’t wait to see what they produce.
What exactly to we stand to gain from lighter batteries? They only amount to a small percentage of the overall vehicle weight so there wouldn’t be any performance gain. The only thing we get from that is less muscles. Do you mean a greater energy density? that takes into account volume and then we can start cramming MAh onto boards and cruise from here to LA without a recharge
Sure, but the weight doesnt really mattter? Like why not go heavier? the performance of the board (Acceleration/braking etc) doesnt really change since even 10 lbs on batteries are only 5% of a 200lb rider/board setup.
I think what @b264 means is he wants more Ah on his board so we can go longer without a recharge and dump more Watts into our motors. At least thats’ what I meant with energy density. Can’t beat good ol gasoline in that regard
I agree that waterproofing, reliability, refueling are all challenges that we face. There are however solutions to all of these with our available resources.
Waterproofing is definitely very doable currently. It’s not really a bottleneck if you want to do it.
Although most folks confuse that with “water resistance” which is not the same thing. Ideally, you have a moderate amount of water resistance and a very high amount of waterproofing.
Waterproofing is the one that matters after water has already gotten inside. Because it always does, eventually.
Well I can tell you have tried hummie hubs. You’ve likely ridden $40 a piece cheap china hubs… You can’t make decent urethane for that even… Get the right stuff and you will fly over cracks, pebbles, and shitty road. But most of the market is crap.
The motor you have to use conformal coating on the sensor board and any low-voltage wiring. It helps on the high-voltage phase wires and terminations, but isn’t absolutely necessary. It is absolutely necessary for the sensor assembly.
A sensorless motor is rather waterproof as-is.
Except bearings… those will need replaced after a certain amount of time.
Not sure waterproofing the gear train matters.But for motors I think they already take a beating, it isn’t like you’re going to submerge the motors in the rain. My batteries have more problems in the rain than the motors, I think the bearings are the biggest problem in the motors in the rain.
