I am on the final stretch of putting everything in its place for my trampa deck build. One question that I am having trouble answering is what are you guys using to keep things in place in your enclosures? And fill up any negative spaces? My guess is some double sided tape to hold electronic in place and then maybe some type of foam to keep everything snug? Or is hot gluing everything in place the solution and not using anything to fill up negative space better?
Am I on the right track?
My enclosure needs to stay flexible because its a bottom mounted enclosure for a trampa deck.
General rule is NOTHING should be held by the enclosure. It should all be fastened to the deck. The enclosure is just a shield. I use foam shims to fill the negative space.
Not the actual question the OP asked but how do you guys actually fill up the empty space. What i really want is to remove the hollow sound you hear when going over bumps
You have to go with the legit 3m or velco stuff I have had “industrial strength” and I was able to pull it off no problem. I laid my battery on my board and just slightly off and it was a bitch to get it off to align it just right on the velcro.
Did you use some foam to close up the space between the battery and the enclosure? If you do that the velcro would get no/less gravity pull. Like this:
