I would like to build a battery pack for my E-Board.
It will probably be a 10s2p, not sure about it yet. I am going to have x2 Maytech VESCs with a current of 50A each. What kind of BMS will I need, in terms of amps?
And do the dual motors that I am going to use will make a difference as well?
200 KV is good for 10s and 30Q are said to be very good cells but I don’t think your gonna be happy with a 10s2p.
You would do much better with 10s4p
The 3510w max power is most likely a misprint
Normally a 6355 190kv with 80a max will be rated around 2200-2400w
I have not seen 3000w from anything smaller than a 6374
I would suggest a motor that can handle 80a anyway.
This one: it has a built in anti-spark on/off switch and is rated for discharge 80a continuous and up to 240a peak
Charge 20a
I run dual vescs set at 80a motor and 60a battery each and have no problem at all with this bms.
you could also not use a bms. just put balance leads on your packs and you can balance charge with any $30 hobby charger. You don’t need balancing or management for discharging.
If my motor is rated as 65A for max current, will it be okay to use the BMS you suggested? In the BMS specs I can see “10S-80A working current”. Does it only related for the charging?
Another thing - I saw people here asked from the manufacture to ship their BMS with specific settings for cutoff start and cutoff end. I’m pretty noob when it comes to it so I’ll be more then thankful if you can help me decide what settings should I ask from the manufacture to set mine.
The bms can handle 80a continuous discharge, up to 240a peak discharge and 20a charge.
I run dual drive. Each vesc is set to 80a motor max and 50a battery max.
That’s 160a and 100a total and I have no problem with the vesc or the bms overheating.
And I’ve got everything inside an almost air tight enclosure.
NOTE: I’m running Ollin 4.12 Vescs with heatsinks.
Just to clarify - your settings are as follow:
(1) Over charge detection voltage: 42.8V±0.025V.(2) Over charge release voltage: 4.08v±0.05V.(3) Over discharge detection voltage: 3.00V±0.05V.(4) Over discharge release voltage: 3.00V±0.1V(5) Over current detection voltage: 0.1V~0.2V
Considering all the parts I use for my setup, will you suggest me to apply your settings for my BMS?
