Hi, i’m currently doing some CAD on my 3d printed enclosure but i’m wondering what you guys use to seal the motor wires going into the enclosure? hot glue? o-rings? nothing?
Also, switches, battery indicators any tips how to seal them as good as possible?
I drilled holes for bullet connectors that were tightly fit and epoxied to the enclosure. Extension cables to the vesc. Motor phase wires plug directly into the bullets, so it’s all sealed up.
For sensor wires I put a rubber grommet on the wire. Will probably add something to give it a better seal on the inside of the enclosure.
These are not as pretty as Deckoz work but you can pass through three motor cables and sensor wire with one smaller gland and that are water proof as well…
Silicone would certainly work, just sand the area you want the silicone to stick too, it doesnt always stick good to smooth surfaces.
I used rubber plugs to seal my esc wires, drilled them out to the wire size I needed. Proper sized grommets are the way to go though.
