opening packages and alotting parts into bins, sanding boxes, base coating boxes, tape and razoring boxes, painting boxes, drilling boxes, cutting boxes, pressing decks, sanding decks, cutting decks, xcarving decks, tape and razoring decks, painting decks, crushing glass, glass gripping decks, testing cells, tack welding packs, wiring packs, wiring BMSs, heat shrinking BMS, wiring eswitches, wiring ESCs for can bus, bulleting ESC phase leads, staining wire channels, wiring channels, potting channels in resin, sanding down resin, drilling decks for rivet nuts, potting rivet nuts in resin, wiring ESCs to eswitch, wiring pack to charge port, setting charge port in box, setting volt meter in box, setting power switch in box, wiring rocker to eswitch, wiring volt meter to eswitches, setting ESCs in box, soldering in PWM leads, soldering receiver, heat shrinking receiver, placing receiver, bolting down box, chopping trucks, clamping trucks, mounting motors, aligning mounts, threadlocking mounts, setting bearings in pulleys, aligning pulleys and belting, creaming bearings, pressing bearings in wheels, machine oiling axles, mounting wheels, plugging motors, heat shrinking phase leads, carving rear riser for sensor leads, extending sensor leads into box via stiffened heat shrink, plugging sensors and coiling them in with phase leads, programming two ESCs, bolting down the box, street testing, updating ESC settings, street testing again, tweaking drive train, tweaking ESC settings some more, more street testing, sealing the box with clear silicone, cleaning the entire board thoroughly, bagging, packing, checking packing, labeling, shipping, paperwork.
24.5 hours is conservative. if i made the deck mods part of the deck cost i feel like things would look more lopsided. i don’t know, i could try it and see what happens.
my goal is total transparency and management of expectations.
