My setting for 10s is “10C”. It doesn’t display voltage though, only percent
Where on the circuit board did you solder the button?
You cant miss it when you take the cover off, its just below the display where the small hole is in the cover, just make sure you’ve got the correct volt meter. The half height meters only have a button on the back.
Cool, I didnt want to make contact between the wrong parts and blow it
