What is this and how do I remove it?
As the title says, I need to remove this white stuff. It is on all of the components from alien power systems. This is a switch that will no longer turn off. Any solution I need to bathe the part in to remove it?image
It is like rubber epoxy I usually just peel it off but if that doesn’t work try epoxy remover
