The standard bushings on Raptor should be fine for lighter riders, just adjust tightness when riding at speed. If heavier rider I do recall maybe Onloop saying change them to tigher ones. You need the balance. Ie do you ride for speed more or carving. Stiffer bushings will reduce manoeuvrability.
Seems like the Raptorās wheels may not be true 80a. So I think the ones I ordered might soft enoughā¦I will compare them on the Raptor and see how it feels
@mr_mahal They might be 80a I was simply wondering if thediffference between 78a and 80acould be o big.
My 78a wheels feel so smooth on tarmac and on the enertion 80a it was a lot of vibration when I was just puhing it for testing purposes.
@Dedbny I will trz to get 75a even though it seems to be difficult to find a dealer in germany who has these flywheels in stock and even harder to find them in 75a
but I need to say @tarzan setup with only one riser looks mutch better to me but i am not sure if i will dare from the beginning
For the Raptor I might just replace the stock risers with equivalent sized shock risers. Might numb some of the vibrations. Iād rather not have to buy another set of flywheelsā¦
@HH1 Iām also wondering the same if 78 vs 80 difference is negligible. In any case, according to the picture I posted above, if youāre using a duro too soft for your weight it means youāll feel rougher terrain more. Would make sense, if the wheel āabsorbsā the impact more because it is soft, you will still feel it, unless itās supposed to work like a shock riser does and just absorbs the vibration never transferring it to the board. Idkā¦Iāll have the Evolve 83mm 76aās to put on the raptor and test the feel eventually. So Iāll see if I really do feel a difference.
really? I would have preferred at least 78a. I think a lower durometer is always better for people who will actually be commuting because most tarmac is not perfect. The ABEC 11 90 mm and 75a would be perfect for us on the raptor.
Lowering the ride height was my only concern with possible wheel bite. In the end the other option maybe to try softer riser for smoother ride as well or just leave with the 2 standards if you have Raptor. All I know is @tarzan is very happy with his raptor set up. I dont like the green wheel, and refer blue ones like Enertion if I can find them in 83 75a but the abec 11 flywheels are not cheap and hrd to get.
Idk man, Iām freaking out over here because I really hope 80a is good enough, Iād be using it on the GT mainly because I need 97mm but I strongly dislike green (or any neon color). For the Raptor, I will try using shock risers before anything else because I really donāt want to buy another set. I wouldnāt use my Raptor for my long range work commute, but probably my shorter, less bumpy after work ones. I say the longer the ride the more important it is.
For reference, the BB wheels were 83a, which is pretty damn hard. They felt ok while going over really rough terrain, but that was probably cause of the flex. I imagine with no flex, the 80a would be fine. Iāll have to compare them all. The evolve wheels are 76a so if that feels awesome Iāll just bite the bullet and get the regular flywheels, but probably dye them black.
I felt the BB wheels were softer than the Raptors. As I felt them both. You can always sell anything you dont need on here. Im sure someone will take them.
That might speak to the authenticity of the duro rating on Raptor wheels thenā¦ I will eventually have access to another Boosted board wheel, Iāll see if thereās much difference between it and my flywheel clone.
Thatās was what I was going to do. But then a bud suggested I google harder and I found some nice clones that are already dyed. If I donāt have to go through that process and spend money/time on dye Iād be happy. I will consider that route if it turns out I donāt like them. Probably would sell them on here as @Dedbny suggested.
the orange ones are 80a, and I have photos of my boosted board wheels where it says 80a.
The other thing is, the 80a on the orangatang wheels are actually gripper and plusher than other 80a wheels. Orangatang had a wider contact patch and they specifically made those wheels for grip. I think there is a video from loaded explaining those wheels on youtube somewhere.
I think you just have to think of the raptor as the board to go fast on good pavement. Works well for you since you have another board that can go anywhere and is being used for commuting.
My bad, I read it wrong on another site. Couldāve sworn it wasnāt. The clones should be somewhat alright then, even if theyāre not as soft.
What Iām realizing is that even when the pavement is shitty, it is usually only shitty for short patches of road. Itās more important for me to have big wheels rather than soft because obstacles (man holes and the like) come up a lot more than rough pavement does. I guess it depends. The Raptor I would never take exploring because I have no idea what Iād be in for. Iād just probably keep it on the road 99% of the time since itās more predictable.
@Mr_Mahal it is a bit my concern to that it might look strange to have a black board with blue trucks and green wheels it might have a bit of an lego appeal to it with that color mixture. I might spray paint my trucks
@Dedbny I might beginn with trying some softer risers before taking one out it would reduce my risk of instant death after buying this board
so I will get some 83mm 75a abecs and some softer risers
Depends on your board. If you have cut outs for the wheels like a lot of drop through boards, you donāt need to worry much about clearance with spacers (though you may still want spacers for things like your mount or motor clearance).
I love the 97ās on both my builds. On my non-dropthrough board, I needed nearly 1" spacers (maybe like 7/8" spacers) to give it enough clearance. Also had to make my trucks moderately tight, which Iām fine with since the board goes over 30mph. They take obstacles very well and youāre not likely to come to a complete stop unless youāre trying to go up a driveway lip thatās over 2". Not much noticeable difference in torque between them and my 83mm wheels. One board is 78a and the other is 75a, though I canāt really tell a difference between them either.
All in all, Iād recommend them for any board assuming youāre okay with the extra weight and size, and if you have the clearance for it. My main gripes with it are the color and contact patch. Iād rather much have the contact patch of the Evolve GT (or kegel) wheels at 54mm. Iām also a bigger fan of the profile of the GT/kegel wheels.
I have 83mm wheels on my LecDec and one doubt I have is if it would be better with 90mm or even 97mm. I know that increasing the wheel size will have a negative impact in the longboard dynamics, like acceleration and braking. The ESC may not be able to handle the load also.
One plan I have is changing the motor mount to use bigger wheel pulleys with the 90 or 97mm wheels and increase torque but does the new riding experience justifies all the necessary work for this? Also it would be better if I upgraded to a VESC, this would guarantee a better experience for sure.
97ās on the right deck is still my favorite setup.
With a GBomb/Subsonic setup using the deep drop brackets - itās about the same height as Boosted, but awesome ride quality w/ the brackets and big soft 97ās absorbing bumps/cracks/small-children easily.
example of ride height - pretty close - while also 97mm vs 75mm wheels, and w/ this setup (8s 8Ah - about 10-12mi vs boosted 4-5mi (my experience on his board)).
i never got to finish enclosures and some wire cleanup - someone āborrowedā it out of my car when parked at workā¦ Great setup and one of my builds will duplicate w/ some improvements. eventually.
Still love the 97ās if you can find them, and donāt mind the weight of the bigger wheels!
