26km is very slow. However that is easily fixed by using a smaller wheel pulley. Common setups are a 36T wheel pulley with a motor pulley anywhere from 12T to 16T.
Also the 192kV is probably a little better anyways since it’s bigger and has a lower max ERPM.
i have the 192kv sk3 on my board. im using a 9S setup , a 16:36 transmission (2.25:1), 15mm HTD5 belt and 83mm wheels. i weight 120kg and this motor and this ratio has no problem propelling me up to ~40km/h
Circle of 48T htd3 is 48x3mm=144mm and 36T htd5 is 36x5mm=180mm. However you wheel pulley is smaller than it should be so it should give you plenty of speed. But remember that motor pulley is also smaller. If i remember right i did talk to you about this same thing last week. You bought one of those cheap pulley/mount sets from ebay or somewhere?
That is correct. And the setup i made was going to work, but then Hobbyking took the 216kv motor out of order, so i could not order it. and now i need to buy either a 168kv or 192kv. But i cant quite hit the speed i want.
