I’m making a solar powered, foldable board. I’m not looking for a fast board, just a board that can transport small journey’s.
I’m looking at around 18km/h top speed, a 4s 3000mah battery. It says 200kv will get me what i want. do i need more mah? what wattage should the solar panel be? do i need to care about v of solar panel?
Regarding the battery you’d want at least 6s 5000mah, smaller batteries just don’t have the current capacity needed for driving a board and live to tell the tale.
And for the motor a 170kv with 14/36 gearing and 76mm wheels will net you around 20km/h on 6s
yeah, its more of just a test. there will be trays stored under the board that will be pulled out to reveil a solar panel, and i will have a solar panel on the top of the board covered with clear griptape
I was thinking about doing something similar mate, I reckon it might be more efficient to keep the solar panels back at home charging some sealed lead acid batteries.
The sealed lead acid batteries could supply power to a 12v lipo battery charger. This is turn charges your 6s lipo.
And you could carry a spare 6s battery in a backpack. Which has been charged at home on another day.
I realise it’s cool to have the solar panels on board but the power provided by the solar panels are no where near enough to charge your 5000mah 6s.
