I think this one is only usable with a certain ESC and there is no reciever in the picture.
The Hoyt puck is highly regarded and if you wait a bit there will be a more budget friendly version.
At the moment I use the new Flipsky remote which is a slight upgrade from the Nano X.
In your other post you mentioned that you can not access your master vesc because of broken USB. Keep in mind that you have to calibrate your remote in the BLDC or VESCtool when you get a new one.
That’s great man! Big ups to @rey8801!
With the new Flipsky remote you don’t have to calibrate your remote before each ride, the thumbwheel has a whee bit more turning resistance which makes the remote a bit more controllable, I have both remotes the Nano X and the Flipsky and as others have said I got used to it but like the Flipsky a little bit more.
The remote @Linny linked above is highly regarded, it all depends on your preferences. The Benchwheel and the Maytech remote are recommended as well, give it a bit more thought.
