So I’m still in the process of putting together my Evolve Carbon GT restoration using a Focbox Unity, generic 60a BMS from Ebay, 140KV 5065 Racerstar motors (replacing with 170KV 6355 Maytech motors eventually), and a 10s4p battery rated at 10.5AH (soon to be replaced with a 10s5p using 18650 Samsung 30q cells)
I’m just wondering what settings I should be running my board with when setting up the Focbox Unity.
Thank you! Will test 80A out but tbh I did try 60A about a week ago and that was plenty torquey to the point of sticking to slow mode, hopefully 80A is a perfect compromise to just stick to that, otherwise like 50A for R-Spec I guess.
Ah, 80A is definitely more powerful than 60. Since 60 is too much, try 50 then. I always do low numbers and bump it up if i feel like i need more boost.
But 60A battery is good enough. I am on 60A on a 10s4p. A 10s5p might be able to output more but i like to be safe
Okay, but that’d be only if it were possible to draw more than 60a I’m guessing? Given the current motors on the board only do 36a as previously stated it shouldn’t be an issue? (60a was more than enough torque for me though)
Sweet, thanks for your help. Won’t be long 'til I switch out for the 10s5p and 6355 motors anyway so the fun is only just beginning with getting this thing running again.
