Hi, I was wondering what I have to spend the most money on?
I planning on building a dual motor build.
The motors is from hobbyking: 192 kv 6374 for both about 180€ and the ESC is from flipsky it is a dual Vesc 6.6 that cost 250$. The battery I will be using is probably two 6s 2p wired In series batteries.
But I don’t know if for example the ESC is overkill or if I need to spend more money on batteries.
You should spend the most on the protective gear. Other than that, it depends solely on your preferences. If you need more range, spend more on batteries. If you need more comfort, spend more on wheels, etc. I don’t think there’s a simple universal answer.
I would like it to go very fast, I planning on buying 110mm wheels with 218mm trucks and 15mm belt. The link for the kit:
https:///products/dual-motor-mechanical-kit?variant=712352301079
And I don’t really know what deck I will need, I don’t think I can make the build with two enclosures with a flexy deck, so I think I will need some sort of stiff deck.
you can´t compair your e-MTB with somebodys street board. the range will be way different.
the 12s 12Ah pack has 537Wh. With an average consumption of 18Wh/km (which should be already much for a steet board) he still get 30km out of them.
