what size lugs do I need for 8 gauge silicone copper wire in European metric size as the sizes are in mmsquared and its last ting iv to order
3mm is the size you need
that 3mm squared diameter?
Believe so…
think that wrong bro this is a 4.3mm… https://www.amazon.co.uk/Aerzetix-Electric-Insulated-0-5-1-5mm2-Terminals/dp/B01GHKCIQA/ref=sr_1_18?s=diy&ie=UTF8&qid=1511312493&sr=1-18&keywords=3mm+lugs
ya found that doesn’t account for the silicone tho think ill just get some 20/25mm squared ones n fill the gap with solder
I looked for those myself long time ago but didn’t find any that would fit. Bought 1mm copper sheet instead, and made those myself, pretty easy to work with copper, drill and Dremel is all You need.
You could possibly cut the silicone off and heatshrink it
yea just cut the silicone…
