True, but if you change the gearing to maintain the same top-speed the torque output will stay the same pretty much.
Anyway, this went off topic, for a $600 build, it doesn’t matter if you go with a 170 or 190, the performance will be pretty much the same, you just need to gear it differently, choose which motor is in stock/better priced.
i’m trying to find a downside to 2x of those 5s 8000mah cells but i kind of cant.
That’s a 36 volt pack at 288 watt hours, to get that with 2500mah cells you’d have to go, like, 10s3p and even then you’d be 18 short, and that’s $150 worth of cells even from a wholeseller.
Two of these zippys (at the current sale price of $37) is $74, less than half! And the 30C rating on the cells is decent too.
i guess the only annoyance would be wiring the packs up to each other and then to a BMS, but that’s not too bad really, and the end result is being able to use a normal charger for them
true but i just like the added safety and charging ease of a BMS
but…not sure what you mean by vga port mod? i mean currently you need to charge the batteries one at a time using that B6 charger. are you saying there’s a way around that…?
bad news
those cheap zippy 5s1p cells jumped back up to $74
how often do these get discounted though?
also for slightly cheaper than the $148 of a 10s1p, you can get three $48 4s1ps and make a 12s1p with 355 watt hours
if you need cheap lipos you can check my post history, there’s a link to a reddit thread for some price-glitched floureon packs (you can buy 12 4s 5500mah lipos for $130ish). I bought them so if the price is fixed by now i can sell you a couple for cheap (i’ll check that they’re balanced before i send them out but i don’t know yet, but there’s not a snowflake’s chance i’ll nee all of them)
6s 8000mah 15c graphene packs. slap two in series for a 355 watt hour 12s1p
The C rating is a little low, but still 120A output which is fine
also they’re claiming these stay much cooler, which i believe, these could potentially last way longer than normal zippy lipo packs.
$60 a piece means $120 total, which is a really good price for a 44.4 volt 355 watt hour pack, that’s gotta be good for 25mph and 20 miles of range, with a combined pack weight of 4.8 pounds which isn’t particularly light weight compared to a 12s3p 2500mah pack, but it’s not that bad
hell even just one of these things is a 177 watt hour 6s, great for a low end board
I went with DIY because of price, and it seems like Enertion is going to stop making mounts/pullies. However keep in mind the DIY VESC uses lower spec’d components so it would be wise to tune it on the lower side. The mini remote is fine and for decks check out www.skateshred.com, they have a nice selection.
How do I know that they are ridged enough though? I’m 235lbs so I need something strong I assume. I had been looking at http://www.customskateboards.com/ before, saw they have the option to add layers, up to 9, assumed that helps.
they are pretty tight lipped on flex, but a couple things to keep in mind;
-maple will be stiffer than bamboo
-the smaller the wheelbase, the stiffer
-if you don’t like the deck i think you can return it, and they’re only $40 a piece after all
