I also have Flipsky 6374’s and been thinking about getting a GO-FOC DV6 upgrade, but the male bullet connectors on my motors are 4 mm while the bullets on the vesc are 5.5 mm (or 6 mm, it says both in different places on their website). I’m trying to figure out how I would connect the 4 mm motor connectors to the 5.5 mm VESC connectors if I were to get this vesc. Any ideas?
Best idea I’ve got would be to just shove the 4 mm female into the back of the 5.5 mm male and solder it on, then the 5.5 mm male could just plug into the 5.5 mm female on the vesc wires. Not sure if this would be feasible though, never done it.
@edylan
you can just replace bullet connectors either on vesc or motor side. if you dont want to touch them then another viable choice is to make a small extension cable where one end is 4mm and the other end is 5.5mm
