What would be the top speed and range?
well, i am beginner in electric skateboarding and i want to make my own electric skateboard. i have got these parts and i would like to what would be the top speed and average range.i want to build this skateboard for going uphills(around 30-35 % elevation)
motors-190kv electric skateboard motor 6355 battery - space cell pro3 esc - vesc wheels - pneumatic wheels
We need a bit more info: Wheel diameter Wheel pulley size Motor pulley size
Welcome
Have at it
Plug in your numbers … Use 70-75 efficiency
Range IS dependent on many factors which I will not name because you can guess what they are …
The guys with a space cell will hopefully chime in and give you a real world range
Also: rider weight
Please look at this thread as it pertains to you
Welcome to the best e-board forum on the planet! Unless your weight is around 50 lbs. your gonna want a dual motor setup to climb 35% grades with those big wheels. I’m running dual 6355 230 KV, 2650 watt ea. with 12s and have climbed abt a 20% grade with 90mm wheels and felt like the setup handled it but with a generous amount of throttle.
thanks for your reply people. helped me a lot . it seems i need a dual motor and it will work pretty much fine. .
