I just bought a used chinese board (paean H2B) for a really good price. I don’t like the esc that it has in it (feels too binary and unresponsive). Honestly, I just don’t feel safe on it. I also have a wowgo 2s which has a much better esc (hobbywing right?). From what I’ve read, this esc is pretty hard to get and is only for hub motors. Any suggestions on a cheap-ish esc that will work with a belt drive?
There is a belt version one it’s actually called a, esc substitute, but remember buy cheap buy twice, the esc substitute’s have a tendency for half of the esc to die
Your best, cheapest and most reliable option is a loopkey. Basically an XT90-S connector on the positive wire between the battery and ESC, with the mating plug bridged with a wire. To turn stuff on, plug in the key (connector). To turn stuff off, unplug it. Rock simple.
You obviously are trying to build this on a shoestring budget, so don’t even bother with an electronic antispark. They’re expensive and they break.
For an indicator, you can get either a digital voltmeter module that just tells you the voltage, or you can get an actual battery meter module that does the math and tells you a %. Either is available from Amazon, ebay, or many of the esk8 hardware sellers.
