Hi fellow esk8 builders,
Lately my wheels have been slipping a lot. During hard acceleration and braking at low speeds.
I remember a time when I adjusted my acceleration curve and motor amps so it wouldn’t slip, and it never did. I changed these settings with the mobile app. After finding out my ideal settings I went and changed these in the vesc standard settings, and this was when my wheels started slipping again. I’ve tried changing to my ideal settings using the app again, it did not work. Maybe because my wheels have slipped a lot, it lost grip? Or is this a silly thought?
My settings are:
70A motor
-32A motor
30A bat
-12A bat
That certainly is a lot of amps to the motor. Got any pictures of the wheel? You could just swap left and right or front and rear.
Is the belt slipping in the pulley or the wheel slipping in the road? What’s the throttle curve values currently?
I’m pretty sure it’s wheel slipping on the road. Otherwise my belt would have been obliterated by now
Curve is at
-28% Acc
-35% Brake
Expo-natural
That’s a liberal curve, you should be good. I’d lower the motor amps to 60 and the curve to -22/-26, test and see how it performs.
And also lower brake amps?
Because at braking I find it the most annoying. I don’t mind slightly less acceleration
Yeah, you’ll just have to experiment. Maybe some lower during wheels.
