Though, I dont really like dealing with alibaba… I might be ok with aliexpress, as I have ordered from there but alibaba with the inquiry system looks like a lot different deal…
Also it is confusing whenever maytech / fvt work the same… maytech one are without the sticker it seems… and different color (have seen red, also)
Hey @Okami, I ordered mine from Alibaba. You will be dealing with a lady named Jen (I think) if you go that route. It used to be Edward, but he left FVT. I believe Maytech has them in both colors, also. Either company. They are the same ESC.
yeh, that’s the point of this thread also… to tell if these FVT are any better… I would like to think there are a minor difference between them (maytech and fvt) but as of right now (with no reviews) it is really hard to tell…
FVT at least seems to be a bit more decent to me, since I’'ve already got their 6s version and I think it is quite robust… about maytech i’ve heard different things so far
To be clear. Those FVT 12s, DIY opto 12s, and Maytech 12s are all exactly the same hardware and made by FVT.
Just happens that the ones that Maytech is reselling has a bad version of the FVT firmware.
Only difference is the firmware which is solved in the other post i linked to. But to save you the trouble get it directly from FVT with the correct firmware already installed and they have better support than Maytech since its actually their own ESC.
