How about this one?
It doesnt say anywhere in the description whether or not it has balancing function. Other than that it looks fine. Check with the supplier whether or not it has balancing function
Ok I willā¦ Already made a Account on the other Forum. Thx again
Did you found a compatible BMS finally?
Wellā¦ I found the original BMS for the Raptor 2.1 mine was PCB Code 004 this one is a 006!! Below you see the to different board types. I connected the new BMS. And the board start charging to 12% 29 Volts. Then the charger turned from red to green?! I measured the voltage at battery with my meter 29 Volts. Itās the OEM space cell. Board is completely stock.
Damn! I bought an separated BMS (10S 60A) From Aliexpress. FOr now I unpluged everything inside my board. Itās my ultimate test, if the battery still wonāt charge, I gonna have a good base for a DIY. Yeah it suckā¦ Iām just conforting thinking than now I know more about eSk8 DIY
Donāt notice that on pic didnāt upload right. Now u see the difference
An auto balancing BMS will do the job. I waiting for my new BMS to see if it balance the battery and keep charging until 100%. If not, from my search, it will meen the battery is faulty soā¦ Yup, gonna have to change the battery too. If anybody else have opinion, please go for it!
