Yea, I’m loving the looser throttle, the far travel and the ergonomics. I also prefer thumb control over trigger. Battery also seems pretty great.
I think I’m using an older revision so I purchased a sample from the company to test out their new receiver with a wire antenna. If everything goes well it should be up for sale in October.
Used this one from aliexpress for a while, really liked it: 2.5Ghz mini remote,
guess it’s the same one as the TB mini controller or the esk8.de mini remote (only a guess, they just look so similar), but looks like I killed the antenna of the receiver with vibrations, so using the “Quanum 2.4Ghz 3ch Pistol Grip Tx & Rx System” temporarily, which so far works too.
Put in a vote for the TB mini controller, hope thats ok.
i use the chozen mod/penguin mod for the G2TB Controller made by @MasterCho. Its amazing, comes in a bunch of different colours and you don’t have to de-solder the usb port for charging. Really useful and convenient
It fixed the range issue but not the acceleration issue. The acceleration issue may be due to the ppm settings on the Vesc. It tended to maintain acceleration for half a second after punching it and letting go of the trigger while unloaded. While loaded (me on the board) I never punched it but felt a little lag on deceleration, however breaks were instantaneous. It may be natural behavior of a ppm controller but I never checked with my other RC controller. It may also be something in the Vesc settings. I ended up buying a nunchuck which doesnt have the deceleration lag.
Been pretty flawless so far. One of mine has a glitch where it may or may not connect when you first start it up, but my other one is fine. To fix, you just turn the remote off and on again, but it never disconnects while riding.
