I did some searching, but wasn’t able to find a post that would help.
Which “variant” should I select for the Focbox Unity?
bigH
bigH
What you need? A remote or a Flipsky esc instead of focbox?
I am looking to buy the remote.
I want to select the correct VX1 “variant” to go with the Focbox.
The list it shows on the site is below:
You could try your luck here:
TLDR: Non VESC (Or VESC PPM mode) works with Unity.
You’ll want the ppm one
It doesn’t matter, it just changes the cables they include. Get one of the VESC4/6 ones so you can use the cables if you decide to use UART control
Thanks everyone!
I got the recommended PPM version.
Could I please see the pinout your cable uses to connect the receiver to the Unity? I couldn’t figure it out on my own and UART doesnt seem to work with VESC6.6
The 6.6 variant has an extra pin so u just need to change it and u are good to go
