500 is really a very high number from what I’ve seen most people stick in the 100-300 range somewhere. Since 18500 rpm is more than twice 7548rpm I’m gonna guess the 500kv10S is going to be more friction and more loss/stress in general (mechanically inefficient). Sure you can do a greater reduction on the higher kv motor but it’s still spinning at that speed and so it’s internal bearings and the shaft are dealing with that extra speed regardless of what you do outside of that. At 12V you’re also going to get more Watts with less amperage and the amperage^2ohms gives you the power loss in wires and the like so the higher voltage is generally more electrically efficient.
edit missed the voltage multiplier but the math stays the same
Usually lower kv motors have more torque than an equivalent motor with higher kv. Lower kv is usually preferred for eSk8, since you want your low end torque to be good for starting from low speed, and for uphill riding.
Then there’s also the concern of what kind of speed controller you’re using. If you are using the VESC, you want to keep the ERPM (kv7voltage) under 60,000 to avoid frying the DRV chip. On 10S, (assume 42V full charge), you need a motor that is 204kv or lower. A 500kv motor like you suggest would fry a VESC. However, you didn’t state your preferred ESC, so this may not be a concern to you.
Ah… ya, I was planning on using VESC, guess im building both setups now as I have half the parts for both and they wont work together, thanks guys, this forum rocks… super fast answers, guess its why this site pops up on google for everything related to vesc and questions in the arena…
Does anyone know where or if I can get 170kv Inrunner motor as that is only what will fit in this setup and must have wires out the back of motor, and not the side.
Someone correct me if I’m wrong, but I believe the ratio between ERPM and RPM is completely dependent on the number of poles on the motor.
The outrunners we typically use on eSk8s have 14 poles, so to get ERPM from RPM, you need to multiply by 7 (number of poles÷2, or 14÷2 in this case). However, I think a lot of inrunners are 4 pole, so you might be able to get away with up to ~700kv if you have a 4 pole motor. If it’s a 2 pole, you can go all the way up to ~1400kv!
Wow, ya that makes a big difference, thank you for reading through and spotting that. My inrunner is 6 pole (500kv x 3 x 37v 10S = 55,500 erpm and may work…
That sounds like it should work. Just go into your VESC settings and limit your ERPM in both directions to 60,000 (or lower, maybe 55,000 or 50,000 as a safety), and it should keep itself from over-revving. I’ve used motors that result in a higher ERPM before (245kv 7 pole on 10S, 72,000 potential ERPM), and just limited the RPM in the settings, and never had a failure. (My only failures have been due to electrical shorts on the motor wires!)
When you say shorts in the motor wires, did the melt down?
What gauge wire should I be using for 12S running 50-125A as I need to run some longer wires about 6ft long to motor from battery.
Thanks,
Another question:
Say my motor has a max amp draw of 125A. If I limit the VESC to max 50A, and the motor is under load with wheel/propeller what issues will I have with motor trying to get up to speed, but does not have all the current it needs?
a. it will max out at 50A and keep running but not up to full speed if load it to high?
b. it will max at 50A until its up to speed then current drops off just to maintain speed?
The VESC has a max motor and a max battery setting
The motor setting will be much higher than the battery setting. Just keep it below 125A and you’ll be good
If u want more than 50 (I just read 40 was enough to lift off the water) you can increase the battery and motor amps to much higher and if it’s too much, and therefore gets too hot, it will just hit an over-temp shut-down and you’ll be fine. If u hook up some water cooling it’d be able to do way more. I think 160 is a possible hardware limit.
The vesc has 2 settings one for Battery max and one for motor max. I’m not sure why there are two but as long as you set the battery max correctly you shouldn’t have an issue
Water cooling is a quite a mess. Especially if you go into any type of saltwater that can eat away at electronics. This would involve a water tight seal with a heat sink.
It’s similar to having a watercooled PC, if the hoses and seals are fine that it is a very good advantage, but if a seal breaks you basically lost your whole system, similar to the vesc, if something shorts in the vesc or battery, you will go flying off your hydrosail .
I’m a long time watercooling PC geek. I’ve killed a PC or two, but out of many, and years of use.
You can run a waterblock - or you can flush fit a heatsink w/ the exterior so it’s exposed to the colder water. Even mounted flush with a layer of CF/GF it’ll cool better than in an enclosed space w/o airflow. The other side FETs are the challenge then, and would need a waterblock most likely. It’s not hard to do it securely, and there are some PC watercooling “kits” now that are fully self contained - you could use a closed loop intended for a CPU/GPU on the top FETs i bet. GIven enough space. Or plumb flow through. I’d look at some of the RC Boat solutions for cooling ESC’s, which might be lighter and simpler. And obviously proven and used for this type of use.
