I’m now researching on which power connector to use to connect my power supply to BMS in the board enclosure.
Power supply I’m after has RCA ( if i’m not mistaken) 10.5 mm connector. I’ve spent some time to find female version but noting waterproof. Power supply is 42V 2A brick.
Here’s a link
A lot of boards use the 3 pin connector ( XLR??) which looks sturdy, unfortunately I couldn’t find female socket which is waterproof or at least with the cover - as I would be afraid it can get water in when mounted on my plastic enertion enclosure. I’m in the UK.
Are 3 pin plugs necessary?
Can you guys share your connectors ? Female and male please.
I guess I’ll chop off 10.5mm connector it comes with and will solder on 5.5 which very common! Found female socket as well, shame 10.5 versions are so rare.
I just spent a few hours working the same thing out. I believe (don’t quote me) the xlr does not have the notch on it. I think the connector used on most the hover boards is called paj3? Meh.
I’ll strick with 5.5mm jack - only rated for 12V … seems to work for a lot of guys here with 10S. If it gets too hot I’ll change it for something similar to yours which must be rated for more volts.
No? If the voltage is your lipo battery fully charged voltage,
for exempel:
LiPo Nominal V(3.7)
Fully Charged = 4.2V
So If you have 10S then its 10S*4.2V= 42V is your fully charged volt.
Basically all you need is a charger that has the same voltage as your fully charged battery.
So that charger could go with no problem if your battery tolerate the amps for it, usually the amp is 2A on the normal laptop chargers.
