Hello everyone this is my first board and it recently stopped working,
I know there are quite a few threads on this already and I’ve tried following most of them with similar setups but it’s still not working out.
With these exact same numbers, I was able to previously get it to work already. I rode it for an entire 3 days but then suddenly it started stopping randomly. I continued riding it then suddenly it just completely stopped working. (When I checked the board, a wire was pulled out of the motor. When I tried plugging it back in, it still didn’t work.
I used 60/-60/30/-12 as suggested by diyelectricskateboards.com My battery is 12S2P with a BMS from @oriol360 My motor is 6374-192KV Brushless Outrunner Motor. (Voltage: 10~12S Lipoly, RPM/V: 192KV, Internal resistance: 0.016 Ohm, Max Loading: 80A, Max Power: 4032W)
I tried rebooting it as @Tampaesk8er suggested. The VESC connects well and I get all the way up to the part where I need to test the motor and let it freely spin. When I click the button the VESC starts flashing red.
Below are photos of my setup.
*P.S. There’s a lot of duct tape because I was just testing it first before drilling everything in permanently.
Thanks everyone!
Debug Console: 2019-06-07 16:50:02: Status: MC configuration updated 2019-06-07 16:50:15: Status: MCCONF Write OK 2019-06-07 16:50:15: Status: MC configuration updated 2019-06-07 16:50:17: Status: MCCONF Write OK 2019-06-07 16:50:17: Status: MC configuration updated 2019-06-07 16:50:33: Status: Bad Detection Result Received
Terminal: AULT_CODE_NONE
Here are screenshots of the setup:
