@elkick where do the measurements for the 30cm begin and end? Is it at the start of the battery cable that leads out of the battery pack, or at the connector?
And where does the measurement end? Is it at the cap PCB of the VESC, or the connection on the main PCB?
Itās measured typically between cells and capPCB. But this is just my own observation and is also related to the cable quality, thickness and how they are mounted (putting +/- close together when routing them across the board might be a good idea). I tested it several times, and every time I went beyond a certain length I had issues.
So I donāt know if others were experiencing the same. Normally I am using 12AWG HK silicon wire. And the BMS wiring might not add to the whole calculation, since itās only at the - cable.
If the wires are too long or building the inductance somehow and messing the FOC upā¦adding caps is a solution right?
Thicker wires with the the red and black as close as possible as was said is a good start.
Iām on Carvon V2 like @elkick 149kv. On my 12s1p LiFePO4 I set my bat max to a conservative 40A even though itās rated for 60A. Switched between FOC and BLDC a few times with no errors. Iām also on PPM with the 2.4ghz Mini Remote.
I have it on a really small deck, 29" kicktail with roughly 13.5" wheelbase so real estate is kind of sparse at the moment. Mostly it using on very short, flat distances in the city.
ah well, couldnt help it and set the new vesc up with foc. on the bench it works well, but I have weird behaviour Id like to ask you guys about: Im using ppm current control no reverse with brake, motor sk6374 -> if I go slight throttle the motor will spin up full -> small torque, no load -> full RPM, check!
now I increase the throttle until max and what happens is the motor is becoming slightly slower (from 41000 ERPM down to 39000 ERPM and the real time data plot shows actually negative power and that its recuperating with about -2A battery current and about -75Watt power. huh?
@whitepony I have always found that FOC mode behaves differently than BDLC mode when itās on the bench, and that seems to be true for startup as well as when I try to move through the RPM range.
Iām sure someone who understands it better could explain why this is, but itās definitely a pattern Iāve noticed with FOC mode (but it doesnāt seem to impact things when Iām actually riding).
I really like @elkickās advice to start configuring FOC from a fresh firmware install, that way no lingering values are impacting your config.
@elkick thanks! Thatās really helpful; I might have to reduce the length of some of my cablesā¦ Iāve for a battery arming switch that is adding a lot of length.
i didnt compare BLDC with foc though - what I had was less ERPM at max compared to min throttle without load on the benchtest with negative power consumption. its just weird behavior that I dont understand.
Sounds like what happens when the voltage limit is hit
Iāve never had that happen on the bench with FOC
Iām using a Kama
But I did feel it riding once when my voltage limit was hit
if i go min throttle the motor starts running slowly, the motors own friction is enough that it doesnt hit ERPM max. so if i increase the throttle further, the motor will eventually run into max ERPM very soon with about 50-75Watt power consumption.
from there, increasing throttle will slowly decrease ERPM and decrease power consumption/battery current until the numbers all become negative eventually. this continues until max throttle!
