All of my builds have all of the electronics secured to the deck. not the enclosure.
Do you add any padding/vibration mitigation between the deck and the components?
Is there such a thing as too much velcro?
Have you used the higher end velcro like 3m dual lock?
I actually prefer using cheaper, dollar store Velcro. It’s fine for holding things securely, and you can Peel up your battery if needed without destroying it lol
There’s no more vibration in the deck than there is in the enclosure. I use Velcro between the deck and components and thin padding between the enclosure and components
I use 3m foam tape. A straight pull will brake your wrists, but pull from the side and let’s go pretty easy.
Have used that too
If you really want a lid use some water tight Tupperware
I found this stuff call sorbothane. they have washers, pads and feet with adhesive on one side. I plan to have this stuff on everything I mount to my board. I have a Redember 44 on the way. I want to minimize the amount of holes i put in such a work of art.
