I was running v4.12 VESCS with v3.3x firmware, and was having trouble with my motors cogging too much at low-moderate speed and high throttle input. Thinking that it had something to do with the FOC parameters, I flashed the VESCs with v2.18 firmware, and re-ran motor detection. The values returned were different, which I then applied to VESCs after reflashing them with v3.3x firmware again- this resulted in a huge improvement in performance- some cogging still occurs, but I could probably just raise my sensorless minimum ERPM up to 8000 or so and live with it.
So why did detection return different values between the firmware versions? Some values stayed pretty much the same, but L for example changed by over x2
Comparing detected/calc’ed parameters between v3.3x and v2.18 firmware:
R from 220mOhm to 195mOhm
L from 60uH to 140uH
lambda stayed about the same
Observer gain from 6 to 7
Current Kp from 0.06 to 0.1415
Current Ki from 225 to 195
I bought them both damaged second hand from different people, but I believe they were both from originally.
I replaced the DRV chip, the STM32 on one of them, and added in the missing cap (on C26 I think)
Ohh cool thanks for the info. As far as motor detection goes I guess it would make sense if they’ve adjusted the parameters to try to avoid blowing the drv, however I don’t think you could get that confirmed by anyone but vedder himself.
I had a similar problem going from firmware 2.18 to 3.38 on focbox. On 3.38, inductance was usually way off, resulting in the motor running rough and throwing over current faults. I tried running detection over and over again at different rotor positions and found that sometimes it would return the same inductance as fw 2.18, which would run smoothly.
