Make sure to wire up your BMS according to the manufacturer’s specifications, but this is the set up you’re looking for
Does he not have a e-switch?
Not from the looks of the first diagrams. If you do @TomasSyster2.0, then wire up the positive and negative to the end switch and channel the voltage through that.
Thx for the help
