Well 2 focboxes, but they are collector’s items by this point, super hard to find.
2 Trampa VESC6 but that might be overkill
Otherwise, I’d just stick with a dual one, they’re at least quite good value. Remember to grab a bms with a switch on it, or a loop key. Don’t get the flipsky antispark, from what i’ve seen its kind of garbage right now.
Also you can run each ESC to its own receiver so if one ESC fails you don’t have total cut-out and failure the other one is still up and going. Pair one remote to 2 receivers - dual independent as @b264 calls it. I discovered this and there’s no going back
I have looked around on some webshops and there is really not many “cheap” parts… by that i mean based in EU, because if i order stuff from outside eu, my wallet is gonna be empty for the next 3 months .
so i found this its gonna be like 189 EUR for 2 of them. but idk if they are safe or good ? what is your opinion guys ?
for remote, I would choose GT2B + some 3D printed mod. this is probably most reliable remote with really long battery life.
for on/off, go with simple xt90-s loop key - cheap and reliable solution.
you can connect two vescs with split ppm - you will need only one receiver, but you will wire it to both vesc at the same time (only 5V wire connects to one vesc only). in this case, you setup every vesc as master with same exact settings. and yes, you can use normal vesc tool or you can use ackmaniac:
