I’d strongly suggest not to purchase from DIYeboard. They’re products are not the greatest and their customer service is exceptionally poor. Just my 2 cents worth
Yes, this pack will work with the vesc. You won’t be plugging the power switch into the esc, it is already installed in the enclosure. Most people wouldn’t recommend this pack, including me, as although it will work you will experience extreme voltage sag during normal cruising.
Just wanted to mention that the voltage sag is not that bad on the 10s5p, its much worse on the 10s2p, the sheer amount of cells somewhat make up for their poor performance. I have the 10s5p pack myself and only experience sag when down to approx 30% which I find okay. Many other better options out there though for lighter and better packs
And regarding your question, yes it will work but be aware that the vesc may be able to pull more juice than the battery/bms can handle, so use conservative settings and ask others on the forum (I am in the process of upgrading to vescs for this pack myself).
And btw you will need an extra kill switch (or loop key), the button that comes with the diyeboard pack is for their built-in killswitch in their esc.
The switch on the kit is for the esc that they also sell. You plug that switch directly into the vesc/ battery and it will go boom boom. No point in buying that complete kit because the battery meter won’t work either. Get a decent antispark and meter or just use a loopkey.
Those cells and the ownboard and meepo etc are the same lg units. The factory that produces the diye stuff is the same factory that supplies all those generic chinese brands and the 5p is the best of a bad bunch saying that it will be a marked improvement on the 2p version.
Better off spending the money on a custom 30q pack. Don’t cheap out on the battery its the heart of the board.
The dickwad who owns that site shared private information of a forum member here recently in a childish outburst. Full name, address, credit card information, email, phone number… the works.
