Will this blow my esc
http://www.hobbyking.com/hobbyking/store/_59056__Turnigy_5000mAh_6S_20C_Lipo_Pack_AR_Warehouse.html?strSearch=6s%205000mah
will this setup blow my esc if so should I just get a vesc?
It depends on your gear ratio and top speed. It likely has a thermal shut off feature that will save it during hill climbing or other high output scenarios. If you decide on a VESC you will want to run it at higher voltages to get the best performance and cool running.
Thanks have u found that ir is ddifficult to get a vesc working?
I build them so I find it quite easy to get them working. :wink:
It is usually an easy setup once you have the bldc-tool running.
I provide my customers with full technical support when it comes to recommended settings and motor configuration. http://www.ollinboardcompany.com/product/vedder-s-speed-controller
thanks! i will certainly be getting a vesc
