Found out my esc to motor cables are too short. I have the Turnegy sk3 6364 190kv which has 4mm bullet connections. It says its 14 Awg wire, which should be fine for (30) 30q cells correct? http://www.ebay.com/itm/4mm-Male-Female-Bullet-Brushless-Motor-Extension-Lead-210mm-/122527669667?hash=item1c8737dda3:g:WmIAAOSwDuJWuOSJ
I believe so yes. If it is the same AWG as your motor wires it should be fine.
