I’m towards the final stages of my very first build. So, to me… My phase wires look ok. I gave them a loop to give slack for movement. I have limited experience and just working from logic. So, any feedback for this set up will be much appreciated.
Nope these are the V2 180 mm. I thought about getting the 218 after I went with the 6355 motors. I sent a pic to the guys at torque board and they said it should be fine.
I like the setup. I spent days going through that thread checking out how everyone does their wiring and I seemed to of missed that. I have a hard plastic riser and a soft plastic riser on it was from amazon. But how high should I go? I’m already at plus 8mm. I guessing another 3mm to cover the wire diameter.
This is how we have been routing them. Our thinking is to choose the path with the least movement for strain relief. One of the leading causes of failure is too much movement of the phase wires where they enter the motor.
Hey chaka can you tell me about the vesc you sell, and do you have a website or anything? I’m going to do a build with the Carvon V4’s 4WD, and am thinking of using those 2s graphene blocks for a 12s setup. I think I am almost ready and know everything I need for the build, but I am new to this and welcome any suggestions.
