When you are wireing a twin vesc, how do you know which to plug the receiver and battery in? Thx
Battery wires are wired in parallel. One VESC is set as master and you can connect a PPM Servo Connector to the 3 pin port and then to your receiver for your remote. You’ll need a servo connector extension.
Think u could do either and just assign it a lower number (not sure if u need to do that even ) and do “send status”. I think I wrote send status on both mine actually and it worked
If a mod closes your thread and advises you to use the search function, opening a new thread is the thing not to do
