Hey, so I almost finished my build and as a remote I wanted a nunchuck. Since I did not get my hands on a Nyko I ordered a similar one. (https://www.amazon.de/gp/product/B001WYAB5W/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1). I soldered all the connections on to the PCB and the other ends on to the VESC. (3,3V, GND, Data and Clock). In the BLDC I chose Nunchuck in the App Configuration and if I display the input amount in the Nunchuck-Tab it shows something.
Now here is the problem:
If I give it full throttle it takes something like 3-6 seconds for the input to go from 50% to 100%, same for any other changes I make to the throttle.
As far as I know changes to the throttle should be displayed immediately…
I did not have the chance yet to test it on the motor, but any idea how to make the input consistent?
The VESC only works with Nyko Kamas.
Any other Nunchuck will not work.
If by any chance you find one let us know - we have all been searching for ages to find an alternative to the Nyko.
I knew that I was making a bet, but I really wanted to try it out. Since I can move the input bar from 0% to 100% it should work with the motor as well right? It would suck though, if the motor took 6 seconds before reacting to my breaking signal…
