Hi, I am a newb and I dont have anything close to a mechatronics degree, so I need some help. Some questions:
I am getting two 5000mAh 20C 5S battery and a 70A motor. I’ve done some calculations and im pretty sure my battries are 100 Amp while my motor is 70 amp. Firstly- is that going to work secondly- If my Vesc says 12 battery and motor is 10S will their be problems
what basic wiring setup should i do. i am connecting the batteries in series, and im going to have a switch, do i still need a anti-spark loop plug or is it fine.
I have no Idea how charging works, do i need a balance charger, this https://hobbyking.com/en_us/hobbyking-b6-ac-dc-compact-lipo-nimh-50w-charger-eu-plug.html, or both EDIT: because i have two batteries, is their a way to charge both. I know their is a parallel charging board but is their any other way
5000mAh 5S batteries are really expensive, what is it okay to go down to?
Thanks Oscar xxXXKOTOXXxx
